It is currently 29 Oct 2025, 10:47
trailer AGAIN
by ChrisH » 06 Jul 2018, 22:06
Zoom in as neededImage
by lewlew100 » 06 Jul 2018, 22:14
That looks exactly right to me - thanks for showing. The winch height is slightly higher than the bow eye, an extended snubber stops any fouling at the towing eye connection and the foremost keel/bow roller is supporting, but not lifting the hull. I presume that the rollers out of site are all doing their bit to support. Geoff.
by Ianfs » 08 Jul 2018, 19:40
I think I'm a bit confused.
On my Roller Coaster the two arms which hold the main rollers swing and the winch has two bow rollers which adjust automatically when the bow is in situ, the winch strap feeds between the two rollers. When the boat rolls off the trailer the towing eye lowers as the boat rolls off.
With your new winch set up, you only have one winch roller which the winch strap goes over for recovery, so the fact that the winch is lower than this must be irellevant or are you saying the weight of the boat and the fact that the winch is lower have bent the winch roller brackets?
by betty boop » 09 Jul 2018, 12:34
The winch was lower but now higher. Hence it pulled into the roller and ‘it’tried to lift the bow up - if I take that roller away boat hit trailer- badly ie no other up front support
New winch can’t go higher only lower defeating the change of post - but a minor adjustment is needed to clear the bow eye vs roller
First trial this weekend was no difference from before so not quite a wasted exercise but only half the problem fixed- she still pulls down into the roller it’s just easier to do it -
by Ianfs » 09 Jul 2018, 14:14
When you roll your boat off the trailer, does the towing eye remain at the same height as the winch roller, go higher or go lower and same question when you're winching back on, is the towing eye higher or the same level as the winch roller or lower?
The reason I've asked, is because I think Geoff has explained what I was thinking but way better and much more straight forward than I.
So here's a thought, it may be stupid so forgive me and be gentle with me but would it be possible to find a welder first then cut the post which supports the winch in between the winch and the roller and angle it downwards. This would hopefully allow you to lift the winch yet again to maybe a height which will do what Geoff has suggested. Shall I get my hat now. :roll: :lol:
by betty boop » 09 Jul 2018, 14:54
Ianfs wrote:When you roll your boat off the trailer, does the towing eye remain at the same height as the winch roller, go higher or go lower and same question when you're winching back on, is the towing eye higher or the same level as the winch roller or lower?
oh dear - get your hat young man...... a worthy suggestion if had it not been just purchased and with no g'teed results - sorry but keep the ideas coming. I'm fixed (not rolling ) on the idea of front supports. my attention is drawn to eBay and the rollers for sale but having seen this picture of Degraff trailers 2600kg model I'm thinking of the idea of moving the forward bunk set - forward. I cant quite see from my pictures at work but the deGraff trailer has its rollers far more forward than the SBS. My thinking being bring it forward (if I can) and the add if req. a set of single or double rollers into the space left over. Degraff sell those 4x roller units for £140.
by Ianfs » 09 Jul 2018, 15:21
I've got my hat. :lol:
Degraff copy the Indespension design of the Super Roller Coaster. The thing is because they are swinging arms and yours is fixed, if you put a set of rollers in front, you would have to set them just right. Great idea but not sure if you mean one set of four along the keel. If so surely the V of the hull further forward rolling onto the rollers through the middle would interfere with the bar of the rollers?
Shall I get my hat again? :lol:
by betty boop » 10 Jul 2018, 10:42
Ianfs wrote:I've got my hat. :lol:
no you're welcome to stay Ian - we'd miss you .
not quite - I mean adding a set of 4 rollers (per stem) on either side forward of midships so they line up either side of the chine rails, think I've said that right. Had a look at Google again searching twin axle roller trailers looking for Karnic or boston whalers shapes on rollers. What I seem to find in 70% of cases is the rollers are forward of the front axle more so than mine. If you recall my moaning of SBS quality a while ago it seems some of that should of been aimed at the set up of the trailer/dealer/package not necessarily SBS themselves and I'm wondering IF this shape of boat/hull should have been set up differently, with so many mistakes being made may be this is just another? Some examples on google have 3 sets of 8 rollers, some 2 sets front and back, some bunks go the full length of the hull- my rollers only support the rear 2/3 of the hull, leaving the front to be unsupported or very little support from crushed rubber/bent spindle V keel rollers.
Geoff will read with a smile that moving the front bent snub roller back is on the cards also but my biggest concern is support and damage I risk causing to myself or the boat by the lack of it upfront. decision time dawns :lol:
by Ianfs » 10 Jul 2018, 15:12
Thanks Ian.
So with the resisntance of the lower front bow roller and maybe the main sets of rollers, could this be a contributing facture to your problems?
by Bigplumbs » 10 Jul 2018, 17:33
I know very little but what about roller bunks
  • In total there are 212 users online :: 1 registered, 0 hidden and 211 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: Google Adsense [Bot] and 211 guests
