There was a sunglasses tray in the centre, and no dedicated depth guage .. and the inbuilt depth gauge on the Rev Counter was too small to be used when underway.
So I added a Depth Trax depth gauge, with adjustable depth alarm … great for waterskiing.
I then added a Zero Off wakeboard speed control in the centre, utilising the sunglasses tray. Achieved by manufacturing a mounting plate and I had that Hydrodipped in Carbon finish.
- Image00001.jpg (609.95 KiB) Viewed 241614 times
However the cheap & nasty wood effect did not cover edge of the dash panel, and corrosion set in.
I removed the dash … you can see the corrosion.
- plate.jpg (308.07 KiB) Viewed 241614 times
Polished it back to plain aluminium
- dash.jpg (91.05 KiB) Viewed 241614 times
Then had it anti-corrosion treated, and then hydro dipped in graphite finish, and an overall ceramic clear coat.
- Image00003.jpg (278.82 KiB) Viewed 241614 times
All assembled it looks to me a lot better than the tatty wood effect.
- finishe.jpg (630.26 KiB) Viewed 241614 times
